dcvm
- 2
- 3
- Severy Kansas
802A when started didn’t produce power. I discovered the “little fuse” was blown so I took the fuse from a 803A and tried again. The voltage was neither 60hz nor 220V and the voltage adjust knob would adjust the voltage. I plugged in a drill and before Any power could be transferred the fuse blew again. I purchased a new voltage regulator but haven’t tested the machine again because I discovered that while the MOV 14D151k resistor had not been installed. The hour meter indicates 90 hours. Where else should I focus my attention while I wait for the resistor to arrive.
