paine
- 23
- 8
- SE Michigan
I have an 803a that I picked out in 2017. I had to do a few things to get her up to snuff as it was an G-planet buy.
One of the issues that I thought I had taken care of was the front main seal.
I recently had a 5 day outage and the old girl was weeping some oil from the same darn seal. SO should I just try replacing the seal again, or maybe try the old trick of just recessing the seal into the gear cover a few MM in effort to give it a new sealing surface on the crank?
Is this a common problem? Do you think I have an underlying issue causing the leak?
Seal in question is #8 in the diagram.
