Ymmit
- 3
- 3
- Glenwood, IA
Getting ready to replace all the fuel supply hoses and the hose supplying the lift pump appears to be molded. Can anyone confirm whether or not it is a molded hose? And if so, where might I find one?
The part is obsolete. This one will work.https://a.co/d/0ioTetfGetting ready to replace all the fuel supply hoses and the hose supplying the lift pump appears to be molded. Can anyone confirm whether or not it is a molded hose? And if so, where might I find one?
I figured as much!It is a moulded hose. It is not available for purchase. You'll have to make due with straight hose.
Thanks Ezgn!The part is obsolete. This one will work.https://a.co/d/0ioTetf
I’m going to try the hose from Amazon that EZGN mentioned. Thanks for the idea thought!Another option can be to make the bends in metal tubing and use a length of hose at each end for the flex.
Yep!As these trucks get older we'll have to get more creative.
