Remote Brake Reservoir- Bubbles when brake applied
Dbluff
40
South Carolina
SS - Hi, just installed BM remote brake reservoir. When applying brake lots of bubbles come up to it and push a lot of fluid out.
Any thoughts?
Bleed all brakes now?
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
Some air will be normal as you are pushing fluid from the remote reservoir into the master reservoir. If you didn't open any of the brake lines you should not need to bleed them.
Dbluff
40
South Carolina
Thinking to amount of fluid I put in, it may have been quite low…
Prob need to bleed, is it pass rear furthest away to do the bleed??
