Cab and spare hydraulics problems M1078 LMTV
Ronmar
7,224
Port angeles wa
That sounds feasible. I'll try to extract those ball seats this weekend. I wonder how many times that cylinder has seized with the trucks in actual service.
IDK, but have sure come across it a lot on the forums. Mine locked up once. Was able to free it, like most people, by repeated up and down cycles. I think the real trick is after you pump up, which should release the safety check, you need to release the pressure very very slowly so it flows past the safety check and releases the stored pressure without triggering the safety. The condition and perhaps the design of the control valve may make that a challenge, so it immediately re-locks the safety when you shift the valve.
i was thinking if it happened again, I might try to pump it up and release the pressure by slowly cracking the hose fitting, but removed that whole crane before it happened again:)
MatthewWBailey
Father, Husband and Barn Hermit
1,401
Mesa, Colorado
You removed the whole crane? So where's your spare now?
Ronmar
7,224
Port angeles wa
It is going to go on the back of the habitat box I have planned. I removed all that hardware for the tire crane, lifting arch and air filter/exp tank, so I could build the habitat right up close to the back of the cab so I can fit a pass-thru. The air-filter is going up on top of the cab. The expansion tank is down behind the bumper.
MatthewWBailey
1,401
Mesa, Colorado
It's been a few months but I wanted to circle back and show you my fix. I bought a 2.5" bore Magister tang cylinder with 1.5" rod. I installed the Prince flow control, as you suggested, on the rod end. Had to buy a "top link knuckle" since the off the shelf cylinders are rotated 90deg on axis vs the original cylinder and I need the ports to face upward. The knuckle took 3 months to arrive! However, oddly, with the knuckle and 16" stroke cylinder, the end-to-end measurement is exactly the same as the original cylinder when retracted. (Must be a conspiracy lol). The increased cylinder volume makes the lifting a little slower, but now there's no worries over those port check valves. Cylinder was $200 online. I had to put an extension hose on the rod end to get back to the original hydraulic lines. It's a bit beefier obviously. 4C82F5C5-2FCB-4733-9765-1E7885324607.jpeg
Awesomeness
1,514
Orlando, FL
It's been a few months but I wanted to circle back and show you my fix. I bought a 2.5" bore Magister tang cylinder with 1.5" rod. I installed the Prince flow control, as you suggested, on the rod end. Had to buy a "top link knuckle" since the off the shelf cylinders are rotated 90deg on axis vs the original cylinder and I need the ports to face upward. The knuckle took 3 months to arrive! However, oddly, with the knuckle and 16" stroke cylinder, the end-to-end measurement is exactly the same as the original cylinder when retracted. (Must be a conspiracy lol). The increased cylinder volume makes the lifting a little slower, but now there's no worries over those port check valves. Cylinder was $200 online. I had to put an extension hose on the rod end to get back to the original hydraulic lines. It's a bit beefier obviously. View attachment 892878
Could you post the part numbers for all the things you used, so others could replicate the build?
MatthewWBailey
1,401
Mesa, Colorado
Sure thing see below. I made the 1" cross pin out of the old cylinder rod (I'm a hoarder) but those are generic. The CAT2 knuckle from QTP was hard to find but I found it at farmingparts.com.
the original pins work fine since the Magister cylinder has 1" holes. The knuckle needs that additional cross pin.
Overall it was a very off the shelf upgrade.
1/4" 2-Wire Hydraulic Hose x 18" with one #4 (1/4") FJIC and one #4 (1/4") MJIC fittingQty1
3/8 NPT 8 GPM Prince WFC-600 In-Line Flow Control 9-7960-6Qty1
Hydraulic Cylinder Welded Double Acting 2.5" Bore 16" Stroke Tang WTG 2.5x16Qty1
SAE 8 Male x 3/8" NPT Male 90 Degree Elbow 6806-08-06 Adapter 9-6806-8-6Qty1
JIC 4 Male x 3/8" NPT Male Straight 2404-04-06 Adapter 9-2404-4-6Qty1
SAE 8 Male x SAE 4 Female Straight 6410-08-04 Adapter 9-6410-8-4Qty1
QTP Knuckle Hydraulic Top Link 25mm CAT2 #53467Qty1
1" x 3-5/8" cross pin for Knuckle. GenericQty1
Total cost: (minus shipping)$315
MatthewWBailey
1,401
Mesa, Colorado
Correction: after a few lifts, it seems the retracted length is 1/2" longer than the original cylinder. I was wrong about the length. The extended length was identical not the retracted.. See pic of crane angle. I used a 3" longer chain so the tire would still sit in the cradle. It's not quite perfect yet but I think I can modify the rod end hole position to make up the difference.
MatthewWBailey
1,401
Mesa, Colorado
Just a final update. Finally finished the rod end hole position mod. I took out 1" of material on either side and then just rewelded it. The tire goes all the way up and into the cradle now.
