MEP-003A Battery sparks a lot when I connect it
Vic_949
12
Bakersfield ca
Vic_949
12
Bakersfield ca
https://www.steelsoldiers.com/attachments/tm-5-6115-585-12-pdf.631487/ I would read pages 134 - 141 in this TM. It has a lot of good information about the starter. BUT...if you are getting high current sparks when connecting your batteries EVEN WITH all of the wires and the cables removed from your starter, then your problem is in the way that your batteries are being connected.
Al so I forgot to tell you this when the connected the battery’s they sparked and the starter turned I see if the master switch was on but it was off
loosegravel
Just a retired mechanic who's having fun!
504
892
Enumclaw, Washington
Does it tell me how to I adjust the metal price in side the starter solenoid
I would read the TM to find out. One other question that I have. When you say that you get "sparks" while connecting your battery cables, are they high current sparks or low current sparks? Is the master control switch in the off position?
loosegravel
504
892
How can I find the glow plug relay and the alternator also when I got the starter brand new I instead correctly and the batterys didn’t spark
Read and study intently the TM that I sent to you. These machines are designed very well, and the more that you get to know yours the easier it gets to troubleshoot things like you’re dealing with. I’m a little confused about your starter. So you have a new one that is causing the battery cables to spark? Or is that with your old one? It sounds like you’re going down a rabbit hole. I’ve been there, it’s no fun. Take things one step at a time. Starters can also be bench tested with a little knowledge. If you have a volt/ohm meter and know how to use it, it’s one of your most valuable tools for tracking down electrical issues. If all of this is above you, it’s ok. None of us know everything. Find a local friend who knows electrical stuff who’s willing to help. Again, I wish that I was closer. I would help.
Guyfang
24,080
Burgkunstadt, Germany
Have you downloaded the -24P TM? have you looked at this picture?
If it did not spark before you took it apart, and now sparks, there is only two possible answers. The wires are not hooked up Properly, or you put the starter back together wrong.
Guyfang
24,080
No. The starter solenoid is a throw away item. So there is no picture, or explanation on how to adjust or repair it.
You do NOT have the wires hooked up correctly.
Vic_949
12
Bakersfield ca
How do I put the starter solenoid back correctly look what I bought the starter brand new hasn’t been taken part off
The battery doesn’t spark 2 days a go when I when to test the starter solenoid I took out those 2 screws and the black wire that comes out from the starter to the solenoid. When I got the new starter I hooked the wires right to we’re they go. After I took r apart the solenoid and put it back and went to connect my battery’s that’s what I notice that they sparked when I connect the last battery terminal. I check if I put the wires right and I did I put them in the same place like the starter wiring diagram.
Vic_949
12
Bakersfield ca
Is there a way to fix the starter solenoid?
428gearhead
52
13
Martinsburg WV
FWIW, the solenoid has two functions- engages the starter to the engine flywheel, but also controls current flow to the starter motor. There is a copper disc inside the solenoid that bridges a set of contacts when the coil is magnetized and the plunger is pulled in. I have seen these weld closed as well as burn up. Try disconnecting battery cable to solenoid, then check continuity between the two large terminals on the solenoid. Should be an open circuit when solenoid is not energized. If not, power is going to starter motor when it should not be.
