Broken nut on regulator
williamh
642
SanDiego Ca.
Was doing some maintenance on the funvee trying to figure out a failure to charge and found the nut on the connector to the voltage regulator was split and letting the plug out. Anyone got a part number ? Or a idea of a replacement that could be sourced from another panel ? I can’t believe that the nut is the only size on a pice of military equipment.
papakb
1,185
San Jose, Ca
People here are more than willing to help you with your problem but your information is pitifully lacking. What HMMWV do you have? What charging system do you have? A picture would have been all that was necessary, Help us help you!
williamh
642
SanDiego Ca.
My bad. On the info. It’s a 72 Dodge Dart w 225 slant 6 but been modified to look like an amc hornet. With a 6.5 non turbo 200a charging system. D22946FD-86EC-4A9B-A9D4-9D65A65FBC2E.jpeg
Milcommoguy
2,265
Rosamond, CA
Run on over to Murphy's surplus warehouse, 401 N Johnson Ave, El Cajon, CA. Lot of military parts like that.
You might get lucky, CAMO
TOBASH
3,488
Brooklyn, NY
My 2007 M1165 has a N3135? What years had or came with N3117?
