Superhondaz50
- 61
- 28
- Fort Mohave, AZ
Hi all, figured I'd start a thread to document this junk truck build as I go along. It's going to be a long project as I only have one or two free days a month. Hopefully have it done within 5 years. The plan is to LS swap it, will be a N/A 5.3, will be cammed with some nice heads and carbureted. May or may not keep the 4L80E, if it is good, I will use it, if not I will use a TH400, it will be converted to 2WD. The whole truck will be gutted to just the frame, cab and hood. All the stock suspension and stuff is going in the trash and will be swapped with a Ford 9" rear on 4 links with 14" 2.5 coilovers and 16" 2.5 bypass shocks. Front will have equal length beams on 14" 2.5 coilovers. Will be topped off with a cage and other goodies. Some details may change as I go along with the build. Today I had a free day and pulled a lot of the front off and the engine. The engine, exhaust and intake part are free if anyone local wants them (I will be dumping other parts too as they come off).
