Mandatory Maintenance
WWRD99
1,715
York Pa
This is why replacing the fuel lines on a machine from auction is NOT OPTIONAL! These machines are zero time and look absolutely brand new.
Got to love the overspray on the engine paint. They painted EVERYTHING.
View attachment 893644View attachment 893645
I did that felt return line on mine but not the other ones. I'll have to figure out what size that is and get some.
Light in the Dark
5,938
MA
I use Gates 1/4" safety stripe for those primary lines, with hose clamps (mainly because I dont stock that little clamp L-P uses). And I use Gates 1/8" for the return lines. Its a bit tighter than OEM, but a little oil, and you've got lines that I've yet to experience a leak with in almost 10 years.
WWRD99
1,715
York Pa
It’s supposed to be 3.5mm. The local auto parts store has 3mm and 4mm of the normal hose. I’m going to get a piece of both sizes and see what works best.
I ordered mine online to get the 3.5 size. Not a big deal at all though as anything that flows will be enough for a return line.
