M51A2 trouble shooting
Hi guys. Long time lurker and first time poster.
Over the winter I purchased a 68 m51a2 that’s been converted to a cargo bed. It ran and drove great when I did take it for a drive but overall I didn’t have much opportunity to take it out over the winter.
Well now that spring is here I decided to take her out and see how she did. On my way back from my buddies farm (just a few miles down the rd) I lost all pressure in the clutch and she went right to the floor. I know Typically this would this be a master cylinder issue. I’m not to familiar with working on these trucks (or anything air over hydraulic) I’ve looked through the TMs and the service manuals but so far no luck. Any help would be appreciated.
thank
ken
I’ve checked the linkage and everything seems to be in check. There is a tiny bit of pressure on the clutch pedal but I have to put the pedal to the floor to feel it.
The clutch is currently engaged (thankfully we were close and could float gears to limp her home)
20,450
By default the clutch would be engaged. Pressure plate holds the disc and the transmission turns. Sucks, but you could crank the truck in first and drive it slowly home or "sync and shift" like it sounded like you may have?
You mentioned hydraulic. Best I can tell that is a mechanical clutch - but I do see reference in this particular book about a "rotochamber". JUST GUESSING, but maybe there is fluid that needs to be in that chamber? (Maybe making it a hydraulic clutch?)
Troubleshooting guide (Technical Manual) TM9-2320-211-20 is here and talks about clutch pedal and linkage on Page 128. Anyhow there are some pictures and troubleshooting steps in the book. I don't have one so I can't give you any first hand knowledge...
Thanks for the info, I’ll have a look at the manual and see if I can find anything out.
That’s exactly how we got it home with the sync n shift. First time I ever had to do it on with a truck this big (luckily there was almost no traffic and only one light)
87cr250r
2,034
Rodeo, Ca
As an avid motorcycle rider clutch masters and rear brake masters often suddenly don't work one day. Very annoying. European bikes or worse because they use mineral oil in the clutch circuit for whatever reason.
Use a volunteer or your phone camera and observe proper movement of the components.
Superthermal
972
Utah, Murray, United States
@5ton-Ulysses How exactly did the throw out bearing fail? Just curious.
Nice info... was looking though the TM's for a solution to my clutch no longer disengaging and found a reference on this thread for that rotochamber....which my rig does not have but, this may be the same problem I am running into. My clutch just after we did my axle work was acting funky, like grab, slip, grab, slip as you would engage the clutch. I thought maybe with having the front bumper on the ground for a few days may have leaked some oil from a possible leaky front transmission seal or something onto the clutch. Anyway, only 90 miles or so since then and now my clutch does not disengage at all. Clutch peddle went little by little every shift closer to the floor until no disengagement virtually at all.
Well, since I'm going to be ripping into this to fix it I might look for a transmission first since my syncros for 2nd and 3rd are for the most part shot.
Bummer. :(
Bummer. :(
@supertthermal. Its been a while but if I'm remembering correctly the bearing ended up seizing. Mechanically the truck runs great but I've seemed to run into some wiring issues. Wire #10 was found dangling underneath the dashboard, would anybody happen to have a wiring schematic for these trucks?
Superthermal
972
The Technical Manual section of SS has all those wiring diagrams. I have found most everything in there. Troubleshooting stuff for odd stuff like this clutch... not so much but lots of details on wiring etc... you should be able to find it in the TM section.
