jahrafa
- 2
- 3
- Orlando, FL
Hello,
I am currently working on a project restoring my 1952 M37. Working on making it street legal first , so that I can have fun and make sure it is solid, and then will tco body work and paint so that it looks nice. No sense in having a nice looking truck that does not drive.
Anyway, I am having a hard time wiring it. I purchased a front wiring harness that was not specified as for early or late model. I assumed it was similar with the difference of the turn signal wiring. My main problem is that I am having a hard time installing it, meaning which side each end of the harness goes to, except the light switch plug of course. One side splits three ways with one of the looms that I can identify is for the horn and temp sender wires. The other side just has several shell connectors.
The other issue I find is that every post about wiring diagrams I see, when I compare the numbers of the wires, I see some numbers with letters on my harness that do not match the diagram. and the diagrams do not show which side of the truck the wires are supposed to go.
Can someone share some wisdom please?
Thank you in advance!
Rafael
Rafael
