loosegravel
Just a retired mechanic who's having fun!
- 504
- 889
- 93
- Enumclaw, Washington
Just thinking out load here. The wheels are turning! Unlike the fuel gauge sending unit which is basically just a variable resistor, the dual float the we’re talking about in this thread I believe is more of an on/off switch for two different purposes. One float I believe is to activate the low fuel fault which will shut the unit down if activated, and the other float I believe is to turn on/off the auxiliary fuel pump. I’m thinking that we could omit the low fuel shutdown and just try to come up with one switch that will turn on/off the auxiliary fuel pump at the correct fuel level. I mean even if the unit doesn’t shutdown for low fuel, the worst outcome from that is the need to refill the tank and prime the fuel system. On the 802’s and the 803’s that only entails turning the S1 to prime/run and let it prime itself. Am I way out in left field?
