- 4,330
- 1,936
- Edmond, Oklahoma
That is not the correct brake lever.
It will not work on the M101 series trailers.
Still not the correct lever for the M101A2
Where did you buy the replacement handles you have? I need to buy one for the same reason you needed them.
M101 Trailer Series: Brand New Brake Levers
FINALLY!! found a brake lever supplier with the help of Guyfang. Their pricey but available. $140 each including spacers. Bolts are not included. Kratzke Machining & Fabricating Company Wittenberg, WI 715/253-3800 They make two different levers. One is a single pull and one is a double...www.steelsoldiers.com
How many of those BIG CountyTime Lemonade Mix containers would you need to sweeten that liquid refreshment???M149A1/2 Water Trailer
Resealed the lower tank hatch gasket.
Sterilized the tank, flushed everything and filled up with clean well water.
Now I have 400 gallons of fresh clean water when needed.
Safety wired the latches and hinge to prevent tampering.
View attachment 894437View attachment 894438View attachment 894440View attachment 894442
Thanks for doing the math!well...if you figure each 82 oz container makes 8 gallons.....I guess you would need about 50 of those. You would definitely be the most popular M149 around!
Indeed!It would be very popular at the park on a Saturday.
Hilarious idea!!!!!
That's a neat tank and trailer. Reminds me of my uncle's military water trailer back in the 90's. He tricked my younger brother to hold the hose for about 30mins filling the tank with slow water flow. I'm coming over tomorrow to help him install the shocks and suspension from 4Wheelonline onto his Wrangler JK. I'll see if he still got some photos of the water trailer.M149A1/2 Water Trailer
What are you going to build??
Not 100% sure yet, but some sort of overlanding/expedition setup. Not sure if I want a hard top or open with hard shell tent.What are you going to build??
.Just won a bid on a M1102 trailer. Plan to pick it up next week and start the building process. Excited to learning from everyone here. Lots of great posts and details I have seen so far.
Take some duct tape and a set of harbour freight magnetic tail lights with you and a hitch to pull pintle hook trailers the trailer is made of aluminum and u will have to tape the light down to something and it has two parking brake levers handles that need to be folded up to release the brake !Just won a bid on a M1102 trailer. Plan to pick it up next week and start the building process. Excited to learning from everyone here. Lots of great posts and details I have seen so far.
