Winter front. M1078
Xengineguy
797
USA Indiana
Position just ahead of charge air cooler . Rests on top with the 90 degree break. The two hose clamps clamp around the cab cross bar
And hold the assembly.. Didn’t take any pictures of it installed, Less than 10 min to install or remove.. just tilt the cab and clamp into place.
Plasa
331
Italy
Not the nicest hack, but works for me: It's a thermo cover for windows, punch a few holes, few cable straps and you're done.
Worked for me also at -30°C, and you can easily flip it up if you are on highway and engine get's hot._20O1550.jpg
Christian
coachgeo
3,477
North of Cincy OH
Worked for me also at -30°C, and you can easily flip it up if you are on highway and engine get's hot.View attachment 894578
Christian
interesting that this helps. The military one blocks air much lower . Which makes since ... think 1/2 to 3/4 of the radiator sits below the grill . hmmm. then again I see now yours appears to tuck down below the grill a bit. How far down does it go?
chucky
19,231
TN .
They used to use stuff like this back in the old days on semi they were air shutters to block the cold air and ice when it just starts to freeze on the radiator fins when you were driving into bad weather but by the mid 70s they seemed to go away and button on winter fronts became the rage with snaps and zippers to adjust how much air you needed s-l500.jpgdownload.jpg
Plasa
331
Italy
It goes nearly down till bottom of the bumper, to cover also the 2 air inlets. What I like is that I can flip it up to get some air through the radiator if temperatures rise. Plus I do not need to rise the cab. At that temps I prefer to be fast.
At -30C engine temp is around 95C, at -10C I can flip the half cover up and temp reach again around 95C, depends on how fast I go.
Christian
Green Mountain Boys
245
Vermont
My solution was not as elegant. I used a large piece of cardboard and wired it to the front of the truck. It definitely helped. I have operated the truck in temperatures as cold as -36C for long periods of time. At those temperatures it really depends how hard you are working the engine relative to the speed of the truck and/or the wind speed.
Ronmar
7,939
Port angeles wa
The rad can pull in a lot of air down below on either side. Here is a pic of the .mil version, like a diaper that bridges and seals that space between intercooler and rad. kind of a pain to install from what I understand… i was thinking a set of tracks on either side of the rad face so I could slide poly panels up in front of the rad face as needed to limit flow thru the rad.
