- 688
- 1,760
- 93
- San Diego, CA
I picked up this victron Phoenix 24 volt inverter with 250 Watts for a really good deal on eBay and plan to install it in the cab of my FMTV to run some power outlets for laptops, etc from. The question is where would be the good place to source the 24 volts and also it has a switch that can be used for remote switching. Should I get that from the dash master power switch via a relay? Should I get it's 24V input lines directly from the batteries, from that battery protection module under the spare tire, or from the electronics panel under the passenger dashboard? I plan to Mount it behind the driver's seat on the floor. I already tested that in the rear most position the seat won't hit it and there's plenty of ventilation from a few different sides.
