- 8,546
- 2,796
- Monrovia, Ca.
There ya go. Swing type fan hub. In the pic, kinda hard to tell, but MOST of the oil leak looks to be concentrated toward the lower part of th acc drive pully, I don't see a large amt of oil on top of the acc drive ear and data plate.
The oil leak looks to me to be from the accessory drive seal. When the swing style fan hub is used, it is extremely easy to over tighten the fan belts to the point that the accessory drive shaft is physically pulled up into the bushing in the front cover and makes it impossible for oil to do it's job.
If I were a bettin' man, I'd bet your next paycheck that your mystery metal is an accessory drive bushing that has failed due to incorrect belt tension.
The repair can go 2 ways.
You pull the accessory drive out, this entails removing the belts and drive pulley then pull the drive/compressor out as a unit, yes, it can be done easily and w/o the pump, it makes it easier! Inspect the front cover. IF the bushing hasn't spun or the shaft hasn't been pulled up into the cover so bad that the bore is now egg shaped or has massive amounts of metal transfer, you can polish the shaft, install a new bushing, and it is a press fit, re assemble and be on your way.
OR
You pull it apart and find that the shaft is FUBAR, and the cover has an oval hole instead of a round one. If that's the case, you either get a new/rebuilt accessory drive assy or a shaft and you rebuild it, they are easy to do, BUT, if the shaft has been pulled on so hard it totally knocks out the bushing in the cover, it usually takes out the bushing in the accesory drive housing, so a new/exch one is better. I forgot, I takes a special tool to remove the spline drive from the shaft too. Then you take the front of the truck apart, remove the front cover and replace it. The pan might need to come down, depending on how hard the pan gasket is and how it comes apart from the ft cover. You can transfer the cam end play shim set from the old cover to the new one with no issues.
If you pull it apart, make sure that the "TDC" mark on the pulley is aligned with the pointer on the cover....for reference, the pin in the acc dr shaft will be at 12o'clock when you pull the pulley off. That is for the timing of the drive, The engine will still run just fine if it is not put back in time, the only thing it times is the overhead set. The next guy will thank you when he sets the overhead.
OR
