Gastrap
- 158
- 43
- Central Iowa
I went to the local fire department to check out an engine noise complaint on their M52A1 brush truck, it has a Deuce bed on it with a water tank. The truck wouldn't even turn over when I got there, it could be barred over about 90° either way, but then stopped solid. I was hoping for a simple head gasket causing a hydro-lock, but found the old ENDT had dropped a valve. This is a DNR program truck, so it may just get turned in for something else instead of an overhaul or swap. Anyone just happen to have a good ENDT laying around? This one was a 70's depot rebuild.
