Fuel Leaking From Fuel Filter Drain Hose CUCV M1009
jplace1011
489
Santa Ana, CA
I noticed the outside of the drain hose is wet. It’s the hose that is located at the bottom of the Fuel Filter. Nothing seems to be loose, I checked. I still have the stock filter installed.
Any ideas what might cause it to leak?
I’m thinking it could be these seals that go with the valves. Part no 5 on the charts, called Performed Packing. I can’t seem to find them anywhere.
Thank you in advance!
jplace1011
489
Santa Ana, CA
Can you see down in there? I bet an O-ring would work, finding the right one might be a challenge.
@nyoffroad I can’t see much of anything, I suspect I’d have to take the filter out. I’m thinking the o-ring/seal on the bottom is going bad. I haven’t found it anywhere.
87cr250r
1,988
Rodeo, Ca
I believe the o-ring is on the drain fittings. You'll have to unscrew it completely. The o-rings is available but you'll have to measure it. Mine hasn't started leaking yet but I plan to replace it when it does.
Valor
215
Apple Valley, Ca.
Try a Chevy or GMC dealer with this number: 15535678. I bought one from local dealer back in 2013. Don't know if the number is any good now though. Good luck.
