Getting there....This question is about the turbo on my M1152A1. It was mainly in storage until sold, 1076 miles.
Dave2018
73
Texas
Ive noticed that the turbo wastegate is opening and closing which is good but dont believe it should be opening much when only driving a short distance below 55 mph. Sometimes it has opened when running through a neighborhood about 40mph. Going to take the service manuals 1 and 2 pdf file to office depot and get them printed next week. Thanks for any information. Dave
  • Like
Reactions: OBX
justinn
211
33
THE GREAT STATE OF TEXAS
The waste gate is just a load(pressure) based actuator IIRC. If the turbo is making pressure, the actuator can be moving. My guess is that the crack pressure is only around 3-4 psi, so cruising under any type of load whatsoever can initiate movement on the actuator/wastegate. If you're heading up an incline at 40mph, it could be fully open, but it all depends on the load.
Justin
Mogman
9,592
Papalote, TX
Justinn is correct it just uses a spring to hold the gate closed and opens on back pressure.
Here is a way to make it adjustable, originally mine was starting to open around 5psi.
Dave2018
73
Texas
Justin
Thanks for the info. Going to get working on it Saturday.
Dave2018
73
Texas
Will be getting this either converted or fixed back to new. Got a Saturday job now.
Thx, dave
