- 963
- 1,822
- 93
- Wauchula, FL
Here’s the scenario, 2003 M1078A1 I’m driving down the beach at the north end of the outer banks NC where they have wild horses roaming around. I turned the CTIS on it come on normal, select XC it aired down as expected. About 1 mile into it I decided to air down to the sand settling again it airs down as expected. Everything is working great I even set the cruise control at about 22mph. About 4 miles into the beach excursion the sand got a little soft and everything started working a little harder and for some reason it kicked the cruise control off! That’s weird and I couldn’t set the cruise again until I actually hit the cruise off switch and back on then I set the cruise again at the same speed with no problem. At about 8 miles in the beach is coming to an end “Virginia state line” and the distance between the dunes and the waves are getting very narrow. And I need to do a U turn so I decided to shift the transmission into off road mode and noticed the display on the shift selector is blank!!! I stopped put it reverse and it goes into reverse put it in neutral and it shifts to neutral put it back in drive and proceed forward and it feels like it in off road mode. But the display is still blank even the round led indicator is not working. Then I noticed the CTIS doesn’t have any leds illuminated. I powered the CTIS off and on a few times and as soon as I turned it on all leds would illuminate for a brief second then off. Not knowing what was going on I did the U turn and went back south. Everything was shifting normally I could even feel it switch transmission modes. As I got closer to pavement I pressed the highway mode on the CTIS and it sounds like it airing the tires up. So still no displays but everything seems to be working. First chance I got to pull over I stopped left the truck running and checked all the tire pressures and they were all pretty close to the set 85psi. I topped off the couple that were a little low got back in the truck and now all the displays are working properly!!!!
Any clues what caused this and how to prevent it in the future. My only guess is when I was in sand mode I hit the over speed but that should just force it into XC mode I think. I just know it freaked me out and didn’t like that type of situation thinking the transmission was flaking out.
