How many gallons of 383 to paint a M1078 w/troop seats
flyfishtrailer
1,041
Cool, CA
Starting to get together my plans to paint my truck green and eventually camo, and just wondering from those of you that have painted a M1078......how many gallons of paint should I orcer?
fuzzytoaster
3,122
Fort Worth, Texas
I've painted a dozen M1078s and Behr Marquee Exterior Flat is the way to go. 5 gallons 383 green if you're doing everything exterior and one more gallon if you want to do inside the frame. 383 Brown I recommend the Rapco rattle cans and you will use 3 or 4 for the truck. Black, use Rustolium huntrng camo black as it's flat and holds its color i.e. doesn't gray with UV and time. You will use way more black than brown on these trucks.
I did this one about 2 years ago. It still looks clean and sharp.
flyfishtrailer
1,041
Cool, CA
Thanks Fuzzy Toaster. Did you thin the Behr with anything or just 5 gallons?
fuzzytoaster
3,122
Fort Worth, Texas
No thinning on the Behr. I want it to apply thick(er) to imitate the CARC and help fill in any scrapes it may have gained over the years. I used an airless sprayer with a 5 gallon bucket to keep application consistent and it helps keep me in my groove when painting. I despise having to take breaks to refill paint, answer the phone, etc.
