Ray70
- 5,585
- West greenwich/RI
You won't be doing anything with the diags plug to troubleshoot this problem.
If I understand you correctly, when you disconnect 136D from S1 the CB no longer pops, but that's simply because you have disconnected power to the CB.
Best bet like LITD said is unplug everything 1 by 1 until it no longer pops when S1 is on.
Disconnect fuel pumps ( both )
then float sensor
lastly fuel pump module.
If its still popping the breaker you will then need to verify wiring and look for chaffed wires, but start by isolating every item downstream from CB1 one piece at a time.
then float sensor
