Westo
- 43
- 18
- Seattle, WA
The resistance between the outer connections of my truck (1114 if it matters) is 85 ohms when on, and 30k ohms when off. Are these figures normal? the relatively low resistance when off seems wrong to me.
Background: I recently put my batteries in again and tried to start it but had some issues. I've started and run the truck before without trouble, although since then I installed headlights and a fuel cutoff. This time there were no problems when I connected the batteries and none when I turned on the truck, but when I started the engine I got smoke from the inner negative terminal and it partially melted. I think it was just a bad connection since the terminal was pretty beat up and deformed, but I've been checking some other stuff since then.
