Yet another request from the collective on a shortcut or procedures to help me save tearing up my hands, destroying my radiator, or breaking my fan. Once the Florida Inferno subsides in 5 months, I am going to replace all the V-Belts on my M998 6.2 NA and replace the Fan Clutch Host with one of the quick disconnect hoses. I have all the parts, matched V-Belts and the Quick Disconnect Hose so replace the cracking hose without a quick disconnect.
So I go to the technical manual(s), and the procedure they have is:
The TM continues:
So here is my dilemma, The fan will not rotate without air pressure being applied via the hose I am trying to R&R to the clutch. So if I was to follow the TM process, seems like one would not be able to break the hose fittings at all as you would loose pressure and the fan will lock up making it hard to get at the hose fittings?!?!?!
What is the trick to be able to get at the hose end with a wrench while the fan is impossible to rotate at all?
Another method I found is a YouTube where they were replacing the water pump, so they removed the hood, removed all the radiators and coolers, and then had excellent access to deal with the Fan Clutch Hose - no problem. There has to be a easier way just to R&R the hose.
So other than removing the whole front of the HMMWV to get access from the front - what is the trick to get the hose off without being able to move the fan blades?
I am just planning to understand how to do this in the coming months when it cools off.
Thank you for the secret!
- It maybe necessary to apply compressed air to clutch adapter. This disengages fan drive clutch to allow access to socket head screws.
The TM continues:
1. Have container ready to catch fluid.
2. Loosen clamp (10) and remove control valve hose (9) from bulkhead adapter (5).
3. Remove bulkhead adapter (5) from bulkhead adapter bushing (.
4. Remove nut (6), washer (7), bulkhead adapter bushing ( and bulkhead adapter (11) from shroud (4).
5. Release fan drive hose quick-disconnect (2) and remove hose (1) from fan drive (3).
6. Remove bulkhead adapter bushing ( from bulkhead adapter (11).
7. Remove bulkhead adapter (11) from fan drive hose (1).
8. Remove female end of quick-disconnect (2) from fan drive hose (1).
9 Remove male end of quick-disconnect (12) from fan drive (3).
