I have a 1300L. It was the absolute tail end of the German military run Ambulance so it has got the 1350 transmission with beefier synchros and a few other 1350 parts along with the OM 366L turbo engine and the "fast axles" that came with the 366L (early 1300s had the OM 352 and are far smokier) I swapped the Ambulance body for a cargo body as the Ambulance body is quite heavy. If know a lot of people build campers with the Ambulance body but its way overkill, far better to start from scratch with lightweight materials like the various pro camper suppliers do. I have far more use for the cargo body and the difference in acceleration and aerodynamics compared to the Ambulance is notiicable. As i did not change the springs its sprung heavy and it rides far better with a ton in the back. I kept the rear anti sway bar from the ambulance.I’m wondering how many U1300L’s are owned by members in the US.
Do you have one?
I have one, 1988, OM366A, fast axles (fire truck) plus Claas OD. Great trucks. I simply set an Alaskan camper in mine. An Alaskan ten foot no cab-over works perfectly. Power-wise I can't tell the camper is there but it cost about 1 mpg on fuel, totally acceptable. I retired mine from camping/travel when I discovered LMTV! The Unimog got twice the mileage!!I’m wondering how many U1300L’s are owned by members in the US.
Do you have one?
Do you like the LMTV better for camping/travel? Whats your opinion on off-roading the LMTV to remote camping and the on-road manners to get the trailhead vs the Mog?I have one, 1988, OM366A, fast axles (fire truck) plus Claas OD. Great trucks. I simply set an Alaskan camper in mine. An Alaskan ten foot no cab-over works perfectly. Power-wise I can't tell the camper is there but it cost about 1 mpg on fuel, totally acceptable. I retired mine from camping/travel when I discovered LMTV! The Unimog got twice the mileage!!
Not sure which one you are referring to. George at Unimog Center is still around. His inventory varies depending on how often he makes it to Europe.@peakbagger do you know what happened to this individual? He seemed to have fallen off the earth or went out of business.
I appreciate the info!@flatwerx
What year M1078 are you getting? The A0's are more "mechanical" than their latter brothers and sisters having less computers/sensors to leave you stranded.(I'm sure you know this already)
Flatwerx, I am happy with the 3.07 ratio by itself and would not consider adding the eco hubs to the 3.07. Even with the 3.90 with eco hubs I feel a less positive shift in the Allison if under load (steep hill, towing). I don't like a soft shift and guess the ECO on top of the 3.07 might exacerbate the slow shifting. Must add though that the ECO hubs with the original 3.90 ratio is a fantastic combination for my-less-than-maximum loaded truck.tennmogger, I appreciate the info. I’m picking up an M1078 next week but always loved Unimogs. It’s good to hear from someone who has both.
Would you ever do Eco Hubs on the truck in conjunction with 3.07 gears?
Thanks, I need to get a large enough garage to be able to work on one year round.@319cssb
I've had this Mog for 7yrs.
It was a 1990 Krankenwagon fully dressed when I got it. I didn't care about the weight...I just wanted something as close to "bear proof" as I could get.
I'm glad I kept it cause over the years I've seen the composite camper boxes opened up like tuna cans from large fuzzy critters.
I grabbed it @ auction in the Netherlands when I was over there hunting for clean Gwagons and Defenders.
@peakbagger
You can get an aftermarket intercooler here in the states if you are crafty and then you don't have to change the hood or lift-block the cab.
You used to be able to "rent" the calibration tools to turn up the pump from Scott @ EI or you could pull it and send it to Mr Couch and he'll do all the work for you.
I got a 30x40’ and it’s still not enoughThanks, I need to get a large enough garage to be able to work on one year round.
No matter what size or how big the shop is I somehow seem to fill it. Thats why you build 3.I got a 30x40’ and it’s still not enough
