Windshield/Dash Fan for the HMMWV
mgFray
990
Southern Minnesota
Driving yesterday I got caught in a rain storm, no big deal got a little wet. But I had to pull over due to the fogging on the inside of the glass. The fan, on high, didn't have enough airflow to keep the window clear.. (ended up clearing the window with my hand until I got somewhere I could buy some paper towels.)
I'd like to avoid this in the future, was talking to someone who was in the Army in the late 90's. They said their unit had installed dash fans from either a bus or the larger trucks (2 1/2 ton/5 ton) that they got from the motor pool and that gave them additional air flow when driving normally, as well as the ability to point it at the windshield if it started fogging up.
Does anyone have any pointers to a decent military, 24V fan and how to go about installing it? (Wiring is the one that I'm not concerned with, she said they just piggy backed off of the wiper motor circuit.)
Thanks!
Coug
4,551
Olympia/WA
I've used my milwaukee 18V work fan a few times, but mostly now use the Red Dot aircon aimed forward at the windshield to keep them clear.
Federal Military Parts has some 24V fans in various colors for the HMMWV, or if you don't mind chrome that one is half the price
Green
Chrome
Coug
4,551
Olympia/WA
juanprado
3,066
Metairie/La (N'awlins)
Federal is out of the box with pricing as they just resell other's products........
Fans like this are standard in Construction equipment and trucking that is 24V. Go to a real NAPA or truck pro or real hd store and they can fix you up with 24v dash fans in black or chrome.
Should also be all over epay or amazon as most non US countries construction equipment is 24v.
I would suggest a simple seperate circuit with toggle switch and in line fuse. Some come with a switch on them. Easy to run under floor mat and feed from battery box. I would not mess with wiper motor circuit, YMMV
Mogman
10,120
Papalote, TX
I second what juanprado said, those contacts in the windshield frame cause enough problems without adding more current to them, shame on Federal for even suggesting it!
Sand
25
Tampa, FL
I've looked all over the place and I cant find which fuse to use. Any ideas?
williamh
676
SanDiego Ca.
Fuses are designed to protect the wire from melting like the circuit breaker at your house. Most products are internally protected by using a thermal switch that opens from heat. There are specialty overloads for single circuit loads but are voltage specific for the amp load.
way too much time lookin at the ugly book.
BEASTMASTER
143
Burgaw, N.C.
when i used to plow with my beast i had a squeege with a 2 foot handle that would reach the passenger side windows i had 3 heaters in that thing and the only way to keep the windows from fogging was to plow with the windows down but it was fun
