rustystud
- 2,806
- Woodinville, Washington
If your kit comes with a fan already on the condenser then you can mount it anywhere there is air flow. For example, on the roof comes to mind ! Yes I know that sounds crazy, but at the transit department I worked at we mounted cooling condensers that had built in fans on the roof all the time. Also mounted plenty under the bus too. If you don't use your truck off-road much, (branches and stuff hitting the condenser would not be good) mounting the condenser on the roof would be the easiest and simplest way.Probably won't be but the kit comes with it and a 2 year warranty, I'm pretty sure it'll void the warranty if I remove the fan
