Lit_Armo
- 9
- 3
- California
Hi I have an M998 with a few issues and I wanted to see if anyone has advice. My front ride side running light (the bulb above the turn signal bulb) is not working, the R turn signal works. My right side headlight would work in high and low beam, but now it started working only in high beam. Also, the front turn signals are weak unless I press the turn signal lever inwards little, like im bending it forward, or when I compress the signal lever system like a sandwich between my hand.
I tried cleaning the corrosion in the R running light bulb housing, but still nothing. My left running light works but it gets so hot it melts the plastic amber cover, I think it's because only that side works and the right doesn't?
I took apart the turn signal lever and cleaned the circle metal ring contacts with rubbing alcohol, it made my turn signals work but its not 100% working like id like.
