spalinko
- 7
- 3
- Divide, Colorado
A previous mechanic started working on a m1090 dump truck he took apart a lot of wiring and disassembled most of the hydraulic systems. I was able to get everything put back together, including the electrical system, Runs Great! bed goes up but will not come down...
I've looked through the technical manual one through five, all the troubleshooting, I've checked that the hydraulic lines are hooked up right, then the electrical systems, there's a brand new four-way valve on it.
The only thing I've found damaged was the valve subplate, the 6x6x6 aluminum block that all the hydraulic lines feed into. There was a plug that was stripped, but with lock tight it is holding and oil pressure. I've been trying to find that Parker subplate, but it's obsolete nobody has one on eBay or anything so I'm trying to get an equivalent part.
I don't think it's the subplane and I don't think it's the four way valve and everything else seems to be working right nothing else has been taken apart any suggestions? is this a common problem?
