WillettRun
- 10
- 3
- Oak Grove, Mo
What should I check for next? I did the install according to the guide and did everything necessary. I do not know where to go from here. I only see 20v AC or so on the gauge.
@WillettRun your in Oak Groove right between Blue Springs / Grainvalley and Bates City?
Ok, I used to live in Blue Springs many moons ago. My buddy Bob McKenzie who owned international motors in Blue Springs lived out there in Oak Grove. I am in Basehor west of the legends / racetrack.Yarp. I work in Lenexa, KS.
Many thanks, I greatly appreciate it,Ok, I used to live in Blue Springs many moons ago. My buddy Bob McKenzie who owned international motors in Blue Springs lived out there in Oak Grove. I am in Basehor west of the legends / racetrack.
I can come out to Oak Groove next weekend in the case you get stuck.
Peter
Kurt here....
Brett, for starters do the following.
1) With the set running measure the AC voltage at the convenience outlet while momentarily putting S1 in in the START position.
The voltage should be about 120 volts AC. What AC voltage do you measure?
2) With the set running measure the DC voltage across the Voltage Regulator terminals 1 & 3 while momentarily putting S1 in in the START position.
The voltage should be about 11 volts DC. What DC voltage do you measure?
To clarify, what does the voltage regulator terminal expect to see in terms of voltage, resistance (or ground) ?The issue is my VR wire M7-I is on the wrong terminal. Move that wire to either M5-I or M6-I
Excellent, thank you! I have power. I can finally finish welding up the bison pen!That wire wants 24 volts DC on it when the set is running. The I terminal on those gauges all get 24 volts supplied to them.
Thank you so much!Excellent it's making power!
The low frequency tells me the Governor Controller thinks the set is in 50 Hz mode.
I'll look at the TM tomorrow and see if I can come up with any suggestlions.
