GOODOMEN
- 7
- 3
- Washington
So I’ve had an issue with my 5 ton lately where I’m driving it and occasionally I’ll let off the gas and then when I go to push the gas pedal back down the truck dies so I have to stop it turn everything off and re-power it in the other day the same thing happened, but this time the truck wouldn’t start so I first started with putting new batteries in and that didn’t do anything there’s no corrosion on any of the connections either and now when I go to turn everything on the fuel pump will not turn on and the power brake light doesn’t turn on. Also, the buzzer doesn’t work anymore for the break not the low air buzzer the buzzer that just goes off when you have the brake on. The low air buzzer wasn’t coming on either. Does anybody have any suggestions?
