Tortuga
- 43
- 13
- Connecticut
1993 AO M1078 Winch
I decided to investigate my non-functioning tach. Followed the TM checking continuity and ohm readings. Ultimately I had a bad reading right at the sensor so I pulled it. The tip is absolutely mangled. This sensor is the J38 connector with sensor on the bell housing.
After looking at the Quick parts ref spreadsheet I can only fine the transmission (29509637) and transfer case (29505601) speed sensors. Anyone have a part number or link available. Thanks in advance.
P.S. Does anyone know why the transfer case speed sensor is so incredibly expensive?!?![IMG_7586.jpeg IMG_7586.jpeg](https://www.steelsoldiers.com/data/attachments/658/658051-bc13e09020ff662871ec39ecfd56dba1.jpg)
![IMG_7585.jpeg IMG_7585.jpeg](https://www.steelsoldiers.com/data/attachments/658/658052-2e70f352313fe0425add2db6152690cd.jpg)
![IMG_7584.jpeg IMG_7584.jpeg](https://www.steelsoldiers.com/data/attachments/658/658054-19985a37fe6fae8a64dc97836206406c.jpg)
