Resolved—- I just sheared off my cab lift piston mount!
GeneralDisorder
5,187
Portland, OR
You're making it more difficult than it needs to be. But you do you.
The spring mount wraps around the frame rail. It's not going anywhere. And not likely to move much.
ramdough
1,729
Austin, Texas
I can’t see mine since my new condenser is in the way. I was mentally envisioning an L shaped perch, but it sounds like from your comment it is a U shaped perch.
Is there anything keeping the bolt heads from spinning or backing out?
GeneralDisorder
5,187
Portland, OR
It's a two-piece U shaped spring shackle mount. Not sure if the bolt heads are captured but the weight of the components will definitely keep them from spinning. I wouldn't take *all* the weight off - just support the truck with less of it's weight on that wheel. Spin them off with an impact and hopefully the cab ram mount just slides off.
chucky
18,961
TN .
I dont get out much but if the cylinder that raises the cab isnt bolted to the piece your replacing why would it have any weight on it or am i missing something ? My only concern is that you have that cab braced GOOOOOOODD or they might find you nailed to the shop floor with the cylinder drove thru you ! If the cab came down before you attach the cylinder to the mount !
Guyfang
23,920
Burgkunstadt, Germany
I have a roof rack, headache rack, some other modifications, full interior with lots of sound deadening….. yes, a bit mor weight.
The issue is the bracket bent and pried the shank off.
I safetied the cab with a ratchet strap, and that alone could move the cab back….. but I need Chucky to try to catch it…. So I did not pull very much.
In an effort to keep Chucky safe, I have come up with a piece of PPE, and need him to send me his address in a PM.
chucky
18,961
TN .
Whats PPE ? PORN / PIE / ENLISTMENT PAPERS !
chucky
18,961
TN .
If your coming down 65 when u cross into TN your a stones throw away ! If its the first week of OCT come down i-75 to knoxville and come to the rally its basically knoxville west /oakridge either way you'll find me !
chucky
18,961
TN .
What rally are you referring to? We were thinking about going to LMTV round up in uwharrie! I think, my wife is the long term planner!
The TN rally used to be GA rally oct THE 2023 SOUTHEAST VEHICLE RALLY OCT 5-8TH its at Winrock offroad park just look under rallies for all the details its about 10 min west of OAKRIDGE TN
chucky
18,961
TN .
This is the 2nd year so its getting its feet on the ground and will be THE RALLY to go to in my opinion ! I think it will turn into a monster once everyone comes to check it one time last year we had a whole nest of members come all the way from south TX and what is it like 75000 acres of trails from mild to nasty /rv park /campsites/ cabins/ or get a hotel in Oakridge 10 min away which is basically west knoxville ! I really enjoyed myself last year and will again this year ! And great vendors i brought a pile of stuff home last time .
