MEP 803a generator.
Sapporo
Alaska
First off thanks for having me. I recently bought an MEP 803 a generator. Frequency meter is reading low but I noticed on the gauge at the bottom there's a screw. Can you turn that to adjust the dial to correct the meter reading. Thanks my name is Scott by the way.
Scoobyshep
1,511
Florida
Yes that can make minor adjustments. Use a multimeter to get an accurate reading. Be advised that the factory frequency meters are not the most robust
Sent from my SM-S908U using Tapatalk
Sapporo
Alaska
Okay I have set it at 61.5 frequency. Hopefully I can make the gauge read the same. Now that I know I can thanks a bunch.
Digger556
608
Denver CO
Welcome to the forums Scott.
Have you read through the TM yet? There is a procedure for testing that meter that measures the current from the transducer and compares it against the machine's frequency. It would be good to verify if the meter is off because of the meter or the transducer.
Sapporo
Alaska
No I haven't I'll look it up thank you.
