FAV #13 Rebuild
Crapgame
329
Navarre, FL
Mine are 3/8”
My calculations for the rear is 14.5" wide x 46" long
The fronts, 15.75" at the square front edge, 23.75" at the widest point where they bolt to the cargo bins, 55" long on the outside edge, 51.5" on the inside edge.
Each car is going to need approximately 17ft of 24" wide 3/8" thick conveyor. Example this 3/8" wide 24" x 40ft will yield enough for 2 cars plus some extra. $321, including shipping for 214lbs.
jshull11873
31
13
Spartanburg, South Carolina
I’m not sure where you are getting your measurements. I had to use a 4’ wide belt. If I remember correctly I bought a 10’ length. I do have a little left over. Enough for 1 more fender in case 1 gets damaged.
