M101a1 trailer rebuild
xjghost
Camden, SC
So I’ve been coming here looking at info and working on a trailer I saved. I picked it up in February this year. Plan was to put it back to as close to factory as I could and convert it to dump. Yes I know these aren’t dump trailers. Plan was to brace the tongue and the pivot mounts where it will rotate. It was free just had to drive up to NC and get it. I live in Camden, SCIMG_4867.jpegIMG_4868.jpegIMG_4869.jpegIMG_4870.jpegIMG_4872.jpegIMG_4873.jpeg
xjghost
Camden, SC
Next mission was to go get some tires and rims. This trailer had none. I found 4 up in NC for $400. So off I went on another adventure.
He bought out a guy retiring from MV restoration and parts sales. He had left hand nuts and 2 more rims. So of course I snagged them too.
xjghost
Camden, SC
I found the cable tube on the braking plate mangled. So it had to be cut off. once mounted the cable appears the right length but the metal shield seems short or I have it mounted in the wrong spot. The pdf says it’s held in place with the bracket and a u bolt.
So here we are. I dismantled the hand brake controller and they are in bad shape. I’ll likely get some new ones.
juanprado
3,073
Metairie/La (N'awlins)
not sure which spring pack you used but the original m116a1e1 I believe has extra leafs for additional weight load capacity around 500 for 3590
xjghost
Camden, SC
Small update. No work done yet. I called Kratzke Machining & Fabricating Company Monday and left a message. He called back Tuesday. I sent an email in about the parts with a picture from this thread. https://www.steelsoldiers.com/threads/m101-trailer-series-brand-new-brake-levers.200176/
Got my quote today of $155 each. PayPal'd $310 and they should ship today. I will update both threads when I get them in hand. I found a piece of 1/5 tube to see if it will work as a replacement to the piece rusted out and crushed on my brake backing plate.
xjghost
Camden, SC
Received them today. Can’t complain about anything. Great service and great communication. Looks to be an exact duplicate to me. My only concern is the fact that mine bent were the stick out from the frame. I might build a dolt on support brace. Now I need tub brackets and how it attaches to the frame and a front leg. I have a line on a parts trailer with all that but it’s $300 I can’t spare right now.
xjghost
Camden, SC
So got it home. Now I have a front gear and 2 more rims. I need to source some good tires. 9R16’s are pricey. Is there any 16” that is a skinny 35” other than Boggers? P-metric?
Also gives me some brackets needed and shows me how the two mate. Hopefully next weekend I can get back at it.
