Deuce Fan mod/ upgrade
SteelNinja
158
Hills of / TN
Guys Ive searched and swore there was a post on changing the Deuce fan out and putting a Duramax fan in its place. Anyone done this ? I cant find the post.. Thanks
WillWagner
2,492
Monrovia, Ca.
This?
cattlerepairman
3,178
NORTH (Canada)
I used a synthetic generic fan from Summit with very satisfactory results. Much less rotating mass and no danger of a fan blade massacring the radiator.
Sent from my SM-G991W using Tapatalk
WillWagner
2,492
Monrovia, Ca.
I wouldn't say no chance, seen plenty of them crack then fail horribly. I had one explode on the dyno, took out the radiator, upper and lower hoses, shroud and a mess of wiring. Had the hood have been closed, pieces parts woulda put holes in the fiberglass hood. Dam thing took out my coffee cup I had on the bench 6 feet away!
cattlerepairman
3,178
NORTH (Canada)
OMG!!
I had those visions for the steel fan!
WillWagner
2,492
Monrovia, Ca.
OMG!!
Steel and aluminum bend when they strike things, yes, sometimes the radiator core gets damaged. Plastic/nylon, once compromised, come apart. On the other hand, I have seen trucks come in with cracked/broken composite fans that when the customer was notified, they just said, yeah, it's been like that for years.
cattlerepairman
3,178
NORTH (Canada)
Here is the original thread with the summit part number. 20" fan. The blades are soft enough to be trimmed with scissors if there is fine tuning required.
SteelNinja
158
Hills of / TN
A composite fan mounted on a clutch-type mount would be nice! I wouldn't intentionally go thru 4-5 ft of water or whatever - so/ but if someone did I would think the clutch may slow it down or maybe stop it from breaking?? I was watching a video when back in the ( maybe 1960's) the military drove the deuce across a river over the cab , What fan would they be using ? i guess the Gov has plenty of funds to fix it tho..
WillWagner
2,492
Monrovia, Ca.
It turns the same way as the engine turns. D-Max fan turns opposite engine rotation.
orren
25
Live Oak, Florida, USA
I found the following years ago:
"Can use a fan clutch off a 1996 F-350. Need 1 ½” set collar welded to the fan hub. Also, longer bolts are needed. Trim new blades to the same diameter as the original blades."
I hope this may help. I could use one of these blade-clutches if you find a couple.
WillWagner
2,492
Monrovia, Ca.
A 96' F-350 so that would probably be a early 7.3 powerstroke, guess ill have to look into that.
Or a gasser, IIRC they had 460s in the std and dually .I am unsure if the fan clutch is directional.
oddshot
116
Jasper, Georgia
DANG!!!!! :oops: I wouldn't have thought you could get a LDT-465 to rev that high.
WillWagner
2,492
Monrovia, Ca.
KW W900 with a 15l 550 hp Cummins in it. Fans are overdriven so are spinning 1.5 or so faster than the engine.
