msgjd
- 3,170
- upstate ny
I can't help you with ideas as my main mep003 is on its original trailer and the other pair of 003's are stationary in the genshed .. Those were moved into place using a bucketloader that set them upon several 2" pipes laid at the doorway , which then were used Roman-style to roll and steer the gennies to their perspective corners at the back of the building .. If I were in your shoes with nothing big available, I would do what you have done, except I would center the axle and set genny so that there's not a horrible amount of tongue weight on the lawn tractor or atv or what have you .. But then again, you might need a lot of weight on that hitch to keep traction with a lawn tractor
