How many kill switches and where?
DEA AK
88
Palos Verdes Estates, CA
I have a M1097A2, I won't be doing any major off-roading, and jumping the grand canyon or anything.
I have read many things on kill switches, placement, etc, so I wanted to ask everyone here (people who actually know a thing or two)...
I think the safest place to put a kill switch would be on the NEG side - easy.
But then doesn't the second battery still have a connection and could possibly drain?
Which would be better?
Thank you,
kendelrio
8,610
Alexandria, La
Thank you,
The batteries are hooked in series. Any "break" in them will result in the vehicle not starting. I have a "+" side kill switch on my M923 and a "-" on my M715. Both work fine. Here is a thread regarding the pros and cons of each.
As far as placement, it depends on whether or not youre looking for hidden or convenient. On my 5 ton, if you know what you're looking for, it's pretty easy to find. On my M715, it's hidden.
On the 5 ton I used this
On my M715, I used this as it allows me to remove the "key".
Best of luck!
DEA AK
88
Best of luck!
thank you very much.
InvictusDecretum
172
33
NC
Best of luck!
Do you know what the amp rating/specific model number is of the 5ton switch ? Or how many amps flow through it on start (I'm assuming the starter/heavy draw components have own relay/ground and don't use that switch).
Looks like there are a few model numbers of that switch with various ratings (up to 175A continuous, with 1000A surge).
