2Pbfeet
- 629
- 93
- Mt. Hamilton, CA
Definitely get some rubber on the pipe strapping. I would stick with at least three or four feet of flex before moving to solid pipe. Getting absorber is easiest to do at the beam, and you probably want it pretty stretchy. You could even pick up some exhaust hangers.I had some olde rubber fire hose I put under the skids to combat that issue now only drone is the strap I hung the exhaust with. Might switch to all thread and pipe hangers.
If it were me, I might experiment with terminating the pipe under the deck vs straight out vs straight out and up. Sound perception can be interesting...
All the best,
2Pbfeet
