- 530
- 837
- 93
- Texas Hill Country
Adding ECO HUBS to our M1078 this weekend is going well except the front axle gear oil is clotted. Not cloudy or milky, black as midnight, clots when cleaning out the wheel hub with metal cleaner. It was difficult to clean out the wheel housings sufficiently. Planning to drop all the gear oil out and at least changing it all again after 500? miles. I recall my dad running kerosene in gunky things for a bit, is that a good idea?
I haven't wiped off the other two from the rear axle. Bearings look good, surfaces of the reduction gears look good, not much metal on the magnet at the wheel hub.
Rear axle gear lube is brown and looked really good, just the front looks nasty.
Please share your thoughts—
