- 74
- 107
- 33
- San Angelo, TX
This^Unless you want to run the 60,000 BTU (not a typo) heater in the van - which requires AC power BTW - you don't need it to connect to anything. That heater is probably ~80 lbs and takes up the whole right side pod that can easily be used for a smaller heater or storage. I stuck a Chinese 12v diesel heater in there in place of the military unit and made a door for the pod. Works great.
The truck is an original M1079Was the truck an actual M1079 or an M1078 w/ the M1079 box?
If the truck is an M1078 you won't have the fuel pump assembly. Easy enough to make one, though.
I can get you some pics in the morning if needed.
Sounds like I'll be looking for another heating option. Although the Farmer's Almanac is predicting a cold, wet and icy winter for west Texas.This^
Mine is sitting n the floor of my garage.
Not only is it LOUD (you can't sleep with it on) it is constantly warming up...blowing fire for two seconds.....cooling down for 5 minutes....warming up again.....rinse, repeat, And it's LOUD .
Did I mention how annoyingly LOUD it is?
The heater is LOUD. And the blower is insanely LOUD.
Even when I was on shore power or generator, I used a tiny electric heater. The artic heater is massive overkill and a HUGE waste of space.
And it's LOUD.
That heater is a waste of fuel and a waste of your time. Uses too much fuel, too much electricity, and takes up a tremendous amount of space. As Third noted - the military didn't give a crap if you could sleep in there - you would be on duty at a desk and likely expected NOT to be sleeping. Chuck that thing in the nearest scrap metal pile.Sounds like I'll be looking for another heating option. Although the Farmer's Almanac is predicting a cold, wet and icy winter for west Texas.
