Finnegan1008
- 162
- 43
- Connecticut
I will check into this. Are there any new solid steel pulleys that work? I have a source for core alternators but I don’t want to have to risk getting a bad pulley
So after checking all of my connections with out any obvious answers. I found a machined steel pulley that is within a few thousandths of being identical to the stamped steel unit. It's only $15 so I figured it was a cheap experiment.
After swapping it in and checking for precise pulley alignment (a thin shim from the hardware store puts this at the exact same alignment as the stock unit). I started it up and with both heat and headlamps running there is zero belt squeal even when cold.
Problem solved.
I will be swapping out the other alternator pulley for one of these units asap. Also I will take pics showing measurements between the stock pulley and this new one.
Also I want to mention the stock pulley wasn't badly bowed out, the 3/8 gates belt still sat within the groove seemingly OK. However there was a little wobble on the stock pulley.
I will post all the details, I need to do a proper write up with pictures and will do so after work when I can do that properly. Stay tuned!Thanks for your post and the information. However it would be helpful to post the source and part numbers for the pulley's and shims you used for those SS members who might want to duplicate your exercise. I don't need the info, as my pulleys are already aligned. But some of the junior members with squealing belts may want to fix their rigs. Just saying......
This may or may not apply, I had a civilian truck with a 6.2 (so did my dad) and both trucks had problems with belts. Gates lasted the longest at about 2 years maybe a bit less. After some research with a friendly NAPA clerk we discovered that there was a "preferred " belt, and all the others were "will fit". I ordered the preferred Gates belt and it had a different shoulder angle to it. It worked well and didn't squeal and lasted for years. My dad finally got one for his and was happy too. No idea if this carried over to CUCV's. Why GM would do something like this is beyond me!So after checking all of my connections with out any obvious answers. I found a machined steel pulley that is within a few thousandths of being identical to the stamped steel unit. It's only $15 so I figured it was a cheap experiment.
Problem solved.
Good thing they are easy to change! I have gates belts on there and it was still squealing the drivers alternator even when guitar string tight until I changed that pulley.This may or may not apply, I had a civilian truck with a 6.2 (so did my dad) and both trucks had problems with belts. Gates lasted the longest at about 2 years maybe a bit less. After some research with a friendly NAPA clerk we discovered that there was a "preferred " belt, and all the others were "will fit". I ordered the preferred Gates belt and it had a different shoulder angle to it. It worked well and didn't squeal and lasted for years. My dad finally got one for his and was happy too. No idea if this carried over to CUCV's. Why GM would do something like this is beyond me!
