1984 M1009: Directional or Turn Signal Lever Mount Broke Inside the Column
Krempely
Simpson 5M9
21
23
Tennessee or BUST
I'm driving along and snap, the turn signal arm flops up and down and no signal. I open up the steering column and this is what I found (see pictures).
Does anyone know the name, model number, nomenclature, or a source for this part? I looked at TM9-2320-289-34P and I don't see this part listed in figure 127.
1984 M1009 turn signal FIRST.jpg1984 M1009 turn signal 02.jpg1984 M1009 turn signal 03.jpg1984 M1009 turn signal 01.jpg
Jeepadict
721
Round Mountain, NV
It looks to me like the turn signal switch housing broke. Fairly easy fix, have to pull the wheel to get to it. Parts easily available from any parts store, or from a Squarebody catalog last time I did one.shouldnt be more than a couple hours work, you'll need a steering wheel puller.
cucvrus
10,438
Jonestown Pennsylvania
That is not really an easy fix. It can be done but requires the entire column to be disassembled. That switch you are holding is the wiper motor switch. 1984 was the first year for the GM Smart Stalk control. Prior to that 1983 models had the dimmer switch on the floor with the push button and the wipers were on the cluster with a push and 3 position slide switch. I outlined this procedure in my decade wrecked thread. 1986 CUCV M1009 Decade after being wrecked. | Page 26 | SteelSoldiers Check this out. And I mentioned before I found it impossible to remove that switch and get everything back together neatly and functioning as designed trying t change it in the truck. Read my post and I have all the pictures it will help you understand why. It is also a great time to clean and re-lube the switches and moving parts inside the column. Good Luck and be gentle. Doing it right the first time is important. Doing the second time and getting the correct results is just wasting time doing it the first time. As mentioned, you will need a steering wheel puller and a lock plate compression tool.
Krempely
Simpson 5M9
21
23
Tennessee or BUST
I found several sources for the Windshield Wiper Switch from $30-$117. Now the process of disassembly, replacement, and reinstallation. I have taken a lot of photos to assist in rebuilding the column and subassemblies. My original wiper switch had the original yellow parts tag 0274 on it.
I purchased a steering wheel puller set from Autozone, Part 57182 / SKU 555516, and can return it (loaner purchase) for a full refund when I'm done. I'm sure other auto parts outlets have the same loaner program. It worked great for pulling the steering wheel and depressing the internal spring. The TMs have not been a reliable source of guidance. IMG-3548.jpgIMG-3554.jpgIMG-3552.jpgIMG-3546.jpg
Thank you CUCVRUS for the original thread and your expertise.
Krempely
Simpson 5M9
21
23
Tennessee or BUST
That rear cover is screwed on from the inside. Did you break it to get it off?
I disassembled the column, slid the first assembly (turn signal ring) out about a quarter inch, and used a screw driver to remove that screw. I separated those two parts and the ignition guide-spring-pin fell out. I’m waiting for a replacement wiper switch and turn signal switch. Then the fun part of reassembly.
Jeepadict
721
Round Mountain, NV
While you're in there, I recall the ignition switch being in the lower part of the column...not a horrible idea to change that out for good measure since you're already in that deep. Also re-greasing the bearings is a no-brainer once you have them clean, there's spring/bearing rebuild kits available if you find worn stuff in there.
Here's another video that may be of interest.
Krempely
Simpson 5M9
21
23
Tennessee or BUST
Project complete and everything works again. It took about 10 hours to remove, disassemble, clean, paint, lube, reassemble, and reinstall the column. I ordered the wiper/washer switch and the turn signal switch from RockAuto.com (see list below for part numbers and price comparisons). These parts can be found at most auto parts stores and online at Amazon and eBay. The parts from Rock Auto were a direct replacement for the original switches (no modification necessary). NOTE: YouTube videos on how to remove and rebuild a 1984 K5 steering column were very helpful.
Rock Auto parts:
1). GM Genuine, Turn Signal Switch, part D6262D, $38.79
2). Std. Motor Prod., Wiper/Washer Switch, part DS811 (DS-811), $30.79 (NOTE: your turn signal lever/arm is inserted into this switch)
I plan to return the loaner steering wheel puller/spring depressor kit for a full refund. The kit (AutoZone, Part 57182 / SKU 555516) was perfect for this repair.
Krempely
Simpson 5M9
21
23
Tennessee or BUST
That’s precisely how I felt. It’s easier than it looks. Take photos and reference the position of each internal and external component as you proceed. The ignition switch is a little tricky, and I recommend replacing it if it is worn out (likely). Otherwise, you need to completely disassemble the column again. Good luck!
Greatthumper
Audubon, NJ
Thank you, after my small mental breakdown, my mechanic said we can do this
kubotaman
132
RI/MI
If you have any decent junkyards left near you, or are lucky with Facebook Marketplace you might be able to find a good deal on a Tilt Column which will also have momentary wipers.
