7th Marines M1008
Curtisje
693
Okinawa, Japan
I don't know what I would do without my M1028 Wrecker. It's easy work picking up the rear axle (or anything else).
I'm really happy with the Chassis Saver. Antique Satin Black is more gloss than I anticipated but it looks great. I can't wait to get the frame back outside and spray this over the Eastwood stuff I used first.
Curtisje
693
Okinawa, Japan
I got some work done on the front axle over the weekend. Balsted some parts for painting. Removed the left side upper kingpin with the aide of heat and a cheater bar. Removed the lower with a large socket, extension and a big hammer. Came out in about 30 seconds.
Bang, bang, bang...
Bang...
Slow progress on my build for sure but it's coming along.
ssgttype
New Jersey
awesome work, keep it up. I'm curious to see how the center mount 6.5 works out. i have a hummer takeout and a civ 6.5, one of which is going into my new to me 1028.
Curtisje
693
Okinawa, Japan
Thank you.
I've decided to relocate the turbo in between the frame behind the cab. I will use a NA 6.2 driver's side exhaust manifold and run pipe from each side back to the turbo.
I have a doubler kit on the way. I need to get the transfer case mounted and the angles right for the drive shafts before I do anything else.
Rutjes
272
Amersfoort, The Netherlands
Thank you.
The other day I came across turbos mounted somewhat like you plan to do. I believe it was on vans. Might be interesting for you to read up on that. Google it. Must've been on The Truck Stop or Diesel Place.
Curtisje
693
Okinawa, Japan
Hard to believe the last time I posted on this was Nov 2021. Time flys. I PCS’d to Okinawa, Japan, in April of 22. I’m back in Twentynine Palms for work but not enough time to wrench on the truck at all. Just cleaned up the garage a little and looked at it. It is patiently waiting for me to finish it up.
Curtisje
693
Okinawa, Japan
Just finished a few days of work on the truck. Took a little leave in conjunction with a TAD trip.
Fabricated a simple tow bar to move the chassis in and out of the garage.
Used the tow truck to pull the engine & transmission out. I need to spray one more coat of chassis paint on the frame next time I'm in town. I also need to take care of a few other frame details that can only be done with the engine removed.
1707265783652_image0.jpegimage0.jpeg1707272458778_image0.jpeg1707272004818_image0.jpeg1707272219948_1707272134969_image0.jpeg1707272130347_image0.jpeg1707272233429_image0.jpegimage1.jpeg1707272329815_image0.jpeg
Wrapped up in plastic for the next year or so.
Good night all.
