Chad Lares
- 39
- 18
- San Tan Valley, AZ
Thanks again guys for all the help in learning the technical part. I'll post another video of this replacement when the new TCM gets here.
Hello, did your transmission light turn on when you turned your ignition on? On your old tcm?
Yes, replaced the entire TCM. Everything works good now. Took it out for a drive and it shifted through the gears normally!Hello, did your transmission light turn on when you turned your ignition on? On your old tcm?
Thanks,
Cory
Is it an6 of these?
Part Number Part Type Price EA Core EA Quantity Total No Vehicle Specified BSETCM609 Automatic Transmission Control Unit (TCU) $ 106.79 $ 45.00 1 $ 151.79 ShippingGround $ 11.99 Tax $ 14.66 Order Total$ 178.44 MasterCard-$ 178.44 Balance Due$ 0.00
Did I miss the one for the turbo?Here is one for the NA, turbo ones are much cheaper
Transmission Control Module Eprom TCM BJDL 6.5 Non Turbo Diesel Engine 1994 and 1995 HMMWV
Transmission Control Module Eprom TCM BJDL 6.5 Non Turbo Diesel Engine 1994 and 1995 HMMWV equipped with 6.5 Liter Diesel Engine NSN 5962014300182 PN 5714647, 16197350www.easternsurplus.net
I could use it. I’m setting up a spare box and internal ‘uter.
