Anyone here a winch wiring expert? My 1986 M998 has a factory installed Warn 6,000lb winch. The controller was cut off at some point and I want to get it working again. I have a black wire, green wire and white wire coming from the winch control module on the winch. I would assume this is where the controller was once attached to. The white wire has 24v to it. Most of the Warn schematics I find show the white wire as power. When I jump the white wire to the black wire the winch appears to go in reverse. When I jump the green wire to the white wire nothing happens. Would this mean my next step is to check the solenoid the green wire is attached to? Or am I doing it wrong and need to have them all wired up to make it work in both directions.. I am assuming if I attached the three wires to a three way throw switch the same thing would happen if the green wire is broken. I.e. it only works in one direction.
