Went off road for the first time recently. I had some trouble shifting the T case. It would grind gears when trying to shift. Park (for the trans) seemed to work for shifting into HL but not always. I took a video
but the only time I got it into L was with the trans in N. Except for my third attempt in the video
I let the truck roll to take and pressure of the drive line etc. what am I missing?
Also for the BTM - I struggled to get it to engage. If I remember what I read - 1800 rpm and light pressure on the brakes? It’s hard to have light pressure on the brakes when you are half way up a hill! I never even got the truck to 1800 rpm in that instance.
I did get it to engage the one time I had the T case in L, but had no luck the other times. Does the Tranfser case have to be in low range for the BTM technique to work?
