Cloudy new soft door window, any suggestions to try to clean/clear?
TOBASH
3,488
Brooklyn, NY
Boat shoppes sell stuff exactly for this. Polishes up the plastic windows well.
Welcome.
Please post images of your rig.
kurtvk
NW Indiana (USA)
I have a new soft door window, but it is very cloudy. I've come to expect a few spots, but this one is well beyond that.
Anyone had any luck clearing up cloudiness on these windows?
If so what did you use?
Thanks
i tried Meguiar's PlastX cleaner, not much luck so far.
Indiana here too, NW Indiana
Patrick_the_Hoosier
13
Indiana
Thanks for the input, I'll skip the PlastX then.
SE Indiana myself.
Thinking about trying Starbrite Clear Plastic Restorer. Saw some impressive before after pictures in the reviews.
If I do I'll let you know how it worked out.
Screenshot_20231117_172251_Amazon Shopping.pngScreenshot_20231117_172254_Amazon Shopping.png
98G
Former SSG
4,429
M813rc
3,254
Near Austin, Texas
I have used Novus 2 polish for over 20 years. We used it at work to keep the lenses on emergency vehicle light bars clear.
When I got my Unimog, it had a cloudy soft-plastic rear cab and side windows that you couldn't see through, so I tried the Novus on those. Turned the plastic crystal clear (which really surprised me!).
I use old (but clean) athletic socks, fluffy side out, as applicator and buffer. Shake the bottle really well, put some on the sock which is over your hand, and gently start rubbing the plastic in a circular manner. I usually work on small areas, around 6" square, at a time.
Do this until you start to get a dry layer on the plastic (a minute or so of rubbing) then use a clean sock (or a t-shirt, or other soft cloth) and gently buff the layer off. Repeat as necessary.
Be patient and gentle, don't rub the polish on too hard or fast, as this generates heat which can distort soft plastic! A buddy of mine didn't heed my warning on that and ended up with some small bulges in his M35 rear window.
There are 1 and 3 grade Novus polishes, but I've never bothered with them.
Cheers
NVAM998
90
Virginia
I just tried the 3 step Novus polish after power washing and soap and water did nothing. Wish I had taken a before picture. There are still some deep scratches but that's good enough for me. Overall, the vinyl is now water clear! Prior to that you couldn't use the side mirrors. Took under an hour.
