GEN 2 lamp went on while driving.
edpdx
75
Oregon
Both GEN lamps light at start up- GEN 2 lamp went on during a drive yesterday- and stayed lit. Been getting readings this morning:
I could use some input here on my results, please.
I just noticed that the front passenger side plug wire had come off of the glow plug- as I remember: Yesterday on the freeway, when the GEN 2 Light came on I noticed a miss developed. I'm heading back out to see if the failed connection caused the GEN 2 Lamp to light up???
Do both GEN lights come on when you turn the key to RUN? YES
Is you truck wiring bone stock or has it been modified? No resistors when purchased- otherwise stock (Doghead relay done)
Remove the 2 pin plug from the alternators and check the voltages. Fill in the blanks.
GEN1 - drivers side
key OFF
small red wire - 12.5 volts
small brown wire - 0.0 volts
Key ON
small red wire - 12.0 volts
small brown wire - 11.9 volts
GEN2 - passenger side
key OFF
small red wire - 12.4 volts
small brown wire - 00.3 volts
Key ON
small red wire - 12.2 volts
small brown wire - 11.8
How do the plugs look? very dirty? corroded? Not checked yet
Battery Voltage - check at the battery terminals of each battery. Don't use the truck for ground.
truck off
front - 12.4 V
rear -12.3V
truck running
front - 14.3V
rear 12.2 V
Batteries: Across both: 26.5 Running/ 24.7 IGN OFF
Rear Batt 12.4 OFF
Frnt Batt 12.3 OFF
WWRD99
1,835
York Pa
I don't think the glow plug wire will turn on anything since it only gets power when the glow plugs are on plus the wire itself is a fusible link...with that being said the glow plug wire could be burned if it was touching ground when you cold started. As far as the charging my guess is regulator since you have the correct power to the regulator but I'd do the alternator test in the sticky of the cucv section. You've all but done the run test of it already.
adf5565
688
Tioga, PA
How’s the belt/tension? I’ve had that happen where it was slipping just a hair and it made the light come on
edpdx
75
Oregon
adf5565, I haven't learned in all the years to check to make sure there is gas in the lawn mower before taking the carb apart. Sad.
I read in another post earlier that the belt tension could be loose. I remembered a tool fell into the moving fan last week when I was doing some work on a leaking injector nipple cap. I went out to check tension and there was no belt on the #2 ALT! I am guessing that the tool damaged the belt and it blew on the freeway yesterday- never heard it snap or wrap?!?
I have a belt (new) to go on in the morning. I am betting that this will fix the problem.
Many thanks to you all who have suffered through my oversight.
Thanks for all helpful comments.
Lothar
661
North Arkansas
I envy the easy fix brought on by an obvious oversight. Could use a couple of those right now.
